Controller Fault LED 'ON' and "Sensor 234 Fault" is reported on NV Battery
Applies to
- AFF A300 / FAS8200
- AFF A800
- AFF A320
- Controller LED on
Issue
- Controller fault LED is on and the NV Battery is reporting a Sensor 234 Fault.
system controller service-event show -instance
Cluster::> system controller service-event show -instance
Node: FAS-01
Service Event ID: 1
Description: Sensor 234 Fault
Timestamp: Sat Jul 23 12:00:13 2022
- SP log shows
Bat_Lrn_Active
start asserted at the same time:
Record 328: Sat Jul 23 12:00:13 2022 [IPMI.notice]: 6701 | 02 | EVT: 0301ffff | Bat_Lrn_Active | Assertion Event, "State Asserted"
Record 329: Sat Jul 23 18:47:41 2022 [IPMI.notice]: 6801 | 02 | EVT: 0300ffff | Bat_Lrn_Active | Assertion Event, "State Deasserted"
