NetApp Knowledge Base
Fan error is not resolved even if the power supply is replaced
340
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • DS224-12
  • ONTAP 9
Issue
  • When a shelf fault occurs, AutoSupport shows 0 as a rotation speed in the shelf 0 cooling unit 4 on both HA nodes.
Example of ENVIRONMENT section in AutoSupport:
    Cooling Unit installed element list: 1, 2, 3, 4; with error: 4
    Cooling Units by element:
      [1] 7550 RPM
      [2] 7420 RPM
      [3] 7520 RPM
      [4] 0 RPM
Example of EMS log:
[?] Thu Apr 02 07:08:45 JST [node02: dsa_worker3: ses.status.fanError:EMERGENCY]: DS224-12 (S/N SHFFGXXXXXXXXXX) shelf 0 on channel 0b cooling fan error for Cooling element 4: critical status; fan is off. This module is on the rear of the shelf on the lower right power supply.
[?] Thu Apr 02 07:08:45 JST [node02: dsa_worker3: callhome.shlf.fan:EMERGENCY]: Call home for SHELF COOLING UNIT FAILED
  • Replacing the power supply 2 of Shelf 0 including the faulty fan 4 doesn't resolve the issue.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
