False switch power fail alerts are generated after power event on Cisco Switch
Applies to
- Cisco Nexus cluster switch
Issue
- There was a power event impacting the switches and following this we see the following alerts in the EMS logs sporadically:
Wed Aug 18 09:15:13 -0400 [node1: cshmd: hm.alert.raised:alert]: Alert Id = SwitchPowerFail_Alert , Alerting Resource = sw1(FOCXXXXXXXX)/PowerSupply-1 raised by monitor cluster-switch
Wed Aug 18 09:15:13 -0400 [node1: cshmd: hm.alert.raised:alert]: Alert Id = SwitchPowerFail_Alert , Alerting Resource = sw1(FOCXXXXXXXX)/PowerSupply-2 raised by monitor cluster-switch
Wed Aug 18 09:15:13 -0400 [node1: cshmd: hm.alert.raised:alert]: Alert Id = SwitchPowerFail_Alert , Alerting Resource = sw2(FOCXXXXXXXX)/PowerSupply-2 raised by monitor cluster-switch
- Health alerts regarding this reappear once cleared although the PSUs have been checked physically and confirmed to be working
- The following is seen from the switch although as mentioned the affected PSU is confirmed to be functioning:
`show environment`
switch1: Power Supply: Voltage: 12 Volts Power Actual Actual Total Supply Model Output Input Capacity Status (Watts ) (Watts ) (Watts ) ------- ---------- --------------- ------ ---------- -------------------- 1 NXA-PAC-650W-PE 0 W 0 W 0 W Shutdown 2 NXA-PAC-650W-PE 0 W 0 W 0 W Shutdown switch2: Power Supply: Voltage: 12 Volts Power Actual Actual Total Supply Model Output Input Capacity Status (Watts ) (Watts ) (Watts ) ------- ---------- --------------- ------ ---------- -------------------- 1 NXA-PAC-650W-PE 84 W 95 W 650 W Ok 2 NXA-PAC-650W-PE 0 W 0 W 0 W Shutdown
