Failed to save Primary Image to Backup flash device
Applies to
- FAS 8200
- AFF A300
- AFF A320
- AFF A200
- AFF A220
- AFF A700s
Issue
- Updating the BIOS firmware fails:
New BIOS version: 11.15
New LOADER version: 6.0.14
Enabling write access to the flash ME region...
ME region - write access enabled.
Saving Primary Image to Backup flash device
fail unlocking memory
Failed. -4 bytes written: I/O error
Failed to save Primary Image to Backup flash device. Programming of Primary aborted
Automatic firmware update skipped (update_flash command failed).
Warning: The boot media contains a newer firmware image (11.15).
Please run 'update_flash' at the Loader prompt to update your
system firmware (11.11).
- Upgrading from the LOADER prompt results in similar errors:
---------.+**** Flash verify failed. ****
*** command status = I/O error(-4)
