NetApp Knowledge Base
FCP adapter reporting "scsitarget.hwpfct.mserr" error with reason code 0x9 and and response code 0x8001 in the EMS
1,847
Visibility:
Votes:
2
Category:
ontap-9
Specialty:
san
Last Updated:
Applies to
  • ONTAP 9
  • FAS Series
Issue
EMS log shows scsitarget.hwpfct.mserr errors with reason code 0x9 and and response code 0x8001
 Example:
[Node-01: fct_tpd_work_thread_0: scsitarget.hwpfct.mserr:debug]: The Fibre Channel fabric management server request (GID_PT) sent from adapter 0e failed with reason code 0x9 (Server unable to perform operation), explanation code 0xa (Port type not registered), and response code 0x8001.
[Node-01: fct_tpd_work_thread_0: scsitarget.hwpfct.mserr:debug]: The Fibre Channel fabric management server request (GID_PT) sent from adapter 0f failed with reason code 0x9 (Server unable to perform operation), explanation code 0xa (Port type not registered), and response code 0x8001.
[Node-01: fct_tpd_work_thread_0: scsitarget.hwpfct.mserr:debug]: The Fibre Channel fabric management server request (GA_NXT) sent from adapter 0e failed with reason code 0x9 (Server unable to perform operation), explanation code 0x1 (Port id not registered), and response code 0x8001.
New to NetApp?
