FAS or AFF controller fails to boot with error "Detected nonencrypting drive or non-FIPS-certified drive xx.xx.x"
Applies to
- FAS/AFF
- ONTAP 9
Issue
- The impaired node has been taken over by the partner node.
- Hardware has been replaced or maintenance was performed on the impaired node.
- The following errors seen during the boot.
Example:
May 24 16:11:38 [localhost:disk.encryptSupportReqd:ALERT]: Detected nonencrypting drive or non-FIPS-certified drive 9c.11.0, but only FIPS-certified drives are supported on this node. 0 of 48 drives checked are FIPS-certified.
May 24 16:11:38 [localhost:diskown.errorDuringIO:error]: error 3 (disk failed) on disk 58CE38EE:206EAC68:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000 (S/N N/A) while opening disk
