NetApp Knowledge Base
FAS9000 The NVRAM battery capacity is critically low (0 cycles) warning
689
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
FAS9000
Issue
The NVRAM battery capacity is critically low (0 cycles) warning and recover soon.
Example:
[?] Sun Sep 06 00:00:31 CST [host1: env_mgr: nvram.battery.capacity.low.critical:EMERGENCY]: The NVRAM battery capacity is critically low (0 cycles). To prevent data loss, the system will shut down in 5 minutes.
[?] Sun Sep 06 00:01:12 CST [mtkhwrd26_n03: env_mgr: nvram.battery.capacity.normal:info]: The NVRAM battery capacity is normal.
[?] Sun Sep 06 00:01:32 CST [host1: env_mgr: callhome.battery.failure:EMERGENCY]: Call home for BATTERY (capacity low) CRITICAL.
New to NetApp?
Scan to view the article on your device
