FAS8700/FAS8300/AFF A400 reports (CHASSIS OVER TEMPERATURE) ERROR warnings
Applies to
- ONTAP 9
- FAS 8300
- AFF A400
- FAS 8700
Issue
- Hourly error messages for chassis temperature. Example:
May 18, 2022 07:16:30 +0200 HA Group Notification (CHASSIS OVER TEMPERATURE) ERROR
- LED1 or LED2 Temp sensor failed. Example:
Cluster::> system node run -node <node name> -command environment chassis list-sensors
Sensor Name State Current Critical Warning Warning Critical
Reading Low Low High High
LED1 Temp failed -- C 0 C 3 C 43 C 46 C
No reading
" outputs for the LED sensors in the BMC debug logs. Example:
LED1_Temp | 16h | ns | 12.1 | No Reading
LED2_Temp | 17h | ns | 12.1 | No Reading
LED1_Temp | na | degrees C | na | na | 0.000 | 3.000 | 43.000 | 46.000 | na
LED2_Temp | na | degrees C | na | na | 0.000 | 3.000 | 43.000 | 46.000 | na
