NetApp Knowledge Base
FAS8060 Multiple fans failed
154
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
FAS8060
Issue
  • Multiple system fans failed.
  • EMS.log shows:
[?] Fri Dec 18 14:54:02 KST [node: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: SysFan1 F1
[?] Fri Dec 18 14:54:02 KST [node: env_mgr: monitor.chassisFan.stop:alert]: Chassis fan contains at least one stopped fan: SysFan1 F1 (failed)
[?] Fri Dec 18 14:54:02 KST [node: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: SysFan1 F2
[?] Fri Dec 18 14:54:02 KST [node: env_mgr: monitor.chassisFan.stop:alert]: Chassis fan contains at least one stopped fan: SysFan1 F2 (failed)
[?] Fri Dec 18 14:54:02 KST [node: env_mgr: monitor.chassisFanFail.xMinShutdown:EMERGENCY]: Multiple Chassis Fan failure: System will shut down in 2 minutes.
[?] Fri Dec 18 14:54:16 KST [node: config_thread: raid.aggr.log.CP.count:debug]: params: {'aggregate_uuid': '0x7f14c792-401cfb6b-f2b4e0bf-4a66d2ac', 'CP_count': '9208063', 'aggregate_type': 'Aggregate', 'home_owner_name': 'node', 'home_owner_id': '537132046', 'aggregate_name': 'node_aggr0'}
[?] Fri Dec 18 14:54:20 KST [node: dsa_vmm: hamsg.connectSucceeded:debug]: params: {'remoteID': '66d64da6b0c111e68de8254a945fa7e2'}
[?] Fri Dec 18 14:54:32 KST [node: env_mgr: callhome.c.fan.fru.shut:error]: Call home for MULTIPLE CHASSIS FAN FAILED: System will shut down in 2 minutes
[?] Fri Dec 18 14:54:39 KST [node: vldb: rdb.ha.verified:notice]: Verified that cluster high availability (HA) is configured correctly, and that on-disk mailboxes are intact.
[?] Fri Dec 18 14:55:00 KST [node: monitor: monitor.globalStatus.critical:critical]: Multiple fans failed: Sysfan1 F2, Sysfan1 F1.
[?] Fri Dec 18 14:55:25 KST [node: dsa_vmm: hamsg.connectSucceeded:debug]: params: {'remoteID': '66d64da6b0c111e68de8254a945fa7e2'}
[?] Fri Dec 18 14:56:32 KST [node: statd: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Multiple fans failed)
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
