FAS500f or AFF-A250 controller running in Single-Path HA with no external shelf
Applies to
- AFF-A250, AFF-C250, ASA-A250, ASA-C250
- FAS500f
Issue
When setting up a new AFF A250, AFF C250, ASA A250, ASA C250 or FAS500f storage system with no external disk shelves, the user may notice that the system is operating in Single-Path HA
mode when checked in sysconfig -a
or storage show disk -p
from the nodeshell:
Example:
NetApp Release 9.8P1: Wed Jan 20 20:14:09 EST 2021
System ID: xxxxxxxxxxx (xxxxxxxxxxx); partner ID: xxxxxxxxxx (xxxxxxxxxxxxxx)
System Serial Number: xxxxxxxxxxxx(xxxxxxxxxxx)
System Rev: A3
System Storage Configuration: Single-Path HA
System ACP Connectivity: Inband Active
SAS2/SAS3 Mixed Stack Support: none
All-Flash Optimized: true
Capacity Optimized: false
All SAN Array: false
Backplane Part Number: 111-04891+A0
Backplane Serial Number: xxxxxxxxxxxxxxxx
slot 0: System Board 2.1 GHz (System Board XXVIII A3)
Model Name: FAS500f
Part Number: 111-04585
Revision: A3
BIOS version: 17.1
Loader version: 6.5.1
Processors: 12
Processor ID: 0x50654
Microcode Version: 0x2006906
Processor type: Intel(R) Xeon(R) D-2164IT CPU @ 2.10GHz
Memory Size: 65408 MB
Memory Attributes: Node Interleaving
Hoisting
Rank Interleaving
Chipkill ECC
NVMEM Size: 8188 MB of Main Memory Used
Controller: B
PCIE Switch 0: id 0 705 1.00
PCIE Switch 1: id 1 705 2.00
TPM FW Version: 5.63.3353.0
Service Processor Status: Online
Firmware Version: 15.1P1
Mgmt MAC Address: xxxxxxxxxxxxxxxx
Ethernet Link: up, 1Gbps
Using DHCP: no
IPv4 configuration:
IP Address: x.x.x.x
Netmask: x.x.x.x
Gateway: x.x.x.x
IPv6 configuration: Disabled
slot 0: Virtual NVMe Host Adapter 0n
0 : NETAPP X4020S173A15TNQF NA51 14651.0GB 4160B/sect (xxxxxxxxxxxxxx)
1 : NETAPP X4020S173A15TNQF NA51 14651.0GB 4160B/sect (xxxxxxxxxxxxxx)
2 : NETAPP X4020S173A15TNQF NA51 14651.0GB 4160B/sect (xxxxxxxxxxxxxx)
<SNIP>
21 : NETAPP X4020S173A15TNQF NA51 14651.0GB 4160B/sect (xxxxxxxxxxxxxx)
22 : NETAPP X4020S173A15TNQF NA51 14651.0GB 4160B/sect (xxxxxxxxxxxxxx)
23 : NETAPP X4020S173A15TNQF NA51 14651.0GB 4160B/sect (xxxxxxxxxxxxxx)
Shelf 0: NS224NSM8E Firmware rev. NSM8E A: 0101 NSM8E B: 0101
<SNIP>
slot 1: 100G Ethernet Controller CX6-Mezz
e1a MAC Address: xxxxxxxxxxxxxx (auto-unknown-fd-down)
e1b MAC Address: xxxxxxxxxxxxxx (auto-unknown-fd-down)
Device Type: CX6 PSID(NAP0000000013)
Firmware Version: 20.28.1002
Part Number: 111-04588
Hardware Revision: A0
