NetApp Knowledge Base
FAS3250 takeover disable by unsynchronized log
731
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS3250
  • Data ONTAP 8.1.4P1
Issue
  • The following error message is displayed on the messages logs:
Example:
Sun Oct 11 12:26:28 KST [node4:cf.fsm.takeoverOfPartnerDisabled:notice]: Failover monitor: takeover of node3 disabled (unsynchronized log).
Sun Oct 11 12:26:33 KST [node4:cf.fsm.takeoverOfPartnerEnabled:notice]: Failover monitor: takeover of node3 enabled
Sun Oct 11 12:28:09 KST [node4:cf.ic.xferTimedOut:error]: raid interconnect transfer timed out
Sun Oct 11 12:28:10 KST [node4:cf.fsm.takeoverOfPartnerDisabled:notice]: Failover monitor: takeover of node3 disabled (unsynchronized log).
Sun Oct 11 12:29:51 KST [node4:cf.ic.xferTimedOut:error]: raid interconnect transfer timed out
Sun Oct 11 12:29:56 KST [node4:cf.fsm.takeoverOfPartnerEnabled:notice]: Failover monitor: takeover of node3 enabled
Sun Oct 11 12:33:14 KST [node4:cf.ic.xferTimedOut:error]: raid interconnect transfer timed out
Sun Oct 11 12:33:20 KST [node4:cf.fsm.takeoverOfPartnerEnabled:notice]: Failover monitor: takeover of node3 enabled
  • "cf status" shows
Example:
node4*> cf status
node3 is up.
node4 has disabled takeover by node3 (unsynchronized log)
RDMA Interconnect is up (Link 0 up, Link 1 up).
node3*> cf status
node4 is up, node4 disabled because of reason (unsynchronized log)
New to NetApp?
