NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
FAS2650 panic reboot
322
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • FAS2650
  • FAS2720
Issue
FS2650 reboots by panic below.
PANIC : PCI Error NMI from device(s):RPT(0,1,0):PLX PCIE 8725 switch on Controller.
version: 9.3: Thu Jan 4 03:00:09 PST 2018
conf : x86_64.optimize
cpuid = 3
Uptime: 1064d21h2m38s
fpudna: fpcurthread == curthread
PANIC: PCI Error NMI from device(s):RPT(0,1,0):PLX PCIE 8725 switch on Controller. in process idle: cpu3 on release 9.3 (C) on Tue Feb 9 17:01:40 JST 2021
compile flags: x86_64.optimize
HA: current time (in sk_msecs) 92005240804 (in sk_cycles) 174404934374763539
DUMPCORE: START
Dumping to disks: 0b.00.23P1
DUMPCORE: END -- coredump written
coredump: compression ms 39164 compressions 12624 bytes in 34107015168 bytes out 8665915679 ratio 393%
comp BW 830MB/s
coredump: write ms 50496 write count 2258 write bytes 8666017792 write BW 163MB/s
coredump: total ms 150138 chunks of all zeroes 383
System rebooting...
Flash Cache NVMe Firmware Version shows ERRORMOD in SYSCONFIG-A.
slot 1: Flash Cache NVMe
Serial Number: XXXXXXXXXXXXXX
Part Number: XXX-XXXXX
Hardware Revision: A0
Firmware Version: ERRORMOD
Model Name: X3310A
Capacity: 512 GB
Vendor Name: Samsung
State: ok
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
