NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
FAS2554 reboots due to l2_watchdog_reset
230
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
FAS2554
Issue
l2_watchdog_reset occurs in the SP log.
Example:
[Tue Jan 19 16:22:56.263 2021] Record 1160: Tue Jan 19 01:50:37 2021 [IPMI Event.critical]: NMI
[Tue Jan 19 16:22:56.263 2021] Record 1161: Tue Jan 19 01:50:38 2021 [IPMI Event.critical]: L2 watchdog timeout hard reset
[Tue Jan 19 16:22:56.263 2021] Record 1162: Tue Jan 19 01:50:38 2021 [Trap Event.critical]: hwassist l2_watchdog_reset (29)
After the motherboard replacement, Ethernet Ports are down due to the following error in EMS log.
Example:
[2021-01-23 06:12:52.709] Fri Jan 22 15:51:29 GMT [node_name:netif.sfpNotSupported:error]: The SFP+ module (unknown ) installed in e0c is not supported with this network interface.
[2021-01-23 06:12:52.874] Fri Jan 22 15:51:29 GMT [node_name:netif.sfpNotSupported:error]: The SFP+ module (unknown ) installed in e0d is not supported with this network interface.
[2021-01-23 06:12:53.044] Fri Jan 22 15:51:29 GMT [node_name:netif.sfpNotSupported:error]: The SFP+ module (unknown ) installed in e0e is not supported with this network interface.
[2021-01-23 06:12:53.207] Fri Jan 22 15:51:29 GMT [node_name:netif.sfpNotSupported:error]: The SFP+ module (unknown ) installed in e0f is not supported with this network interface.
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
