How do shelf product IDs and modules in ONTAP map to a model of a shelf or storage system with embedded storage
Applies to
- Storage Shelves
- AFF, ASA and FAS Systems
Answer
Shelf models and storage systems with embedded storage (which are also considered shelves from a storage perspective) are uniquely identified in ONTAP by examining both the shelf product ID and the shelf module, together. A specific shelf product ID and shelf module combination can be mapped to a model of a shelf or a storage system with embedded storage.
The following is a list of shelves, as they would be reported from a storage perspective in ONTAP:
Shelf Product ID (ONTAP) | Shelf Module | Shelf (Marketing Name) |
NS224NSM100 | NSM100 | NS224 |
DS224-12 | IOM12 or IOM12B | DS224C |
DS212-12 | IOM12 or IOM12B | DS212C |
DS46012 or DS460-12 | IOM12 or IOM12B | DS460C |
DS4486 | IOM6 | DS4486 |
DS2246 | IOM6 | DS2246 |
DS4246 | IOM6 | DS4246 |
DS4243 | IOM3 | DS4243 |
The following is a list of AFF or FAS storage systems with embedded storage, as they would be reported from a storage perspective in ONTAP:
Shelf Product ID (ONTAP) | Shelf Module | Storage Systems |
FS4483PSM3E | PSM3E | AFF A800, AFF C800, ASA A800, ASA C800 |
NS224NSM8E | NSM8E | AFF A250, AFF C250, ASA A250, ASA C250, FAS500f |
DS212-12 | IOM12G | FAS2820 |
FS424-12 | IOM12F | AFF A700s |
DS224-12 | IOM12E | AFF A220, AFF A200, AFF A150, ASA A150, AFF C190, FAS2750, FAS2650 |
DS212-12 | IOM12E | FAS2720, FAS2620 |
DS2246 | IOM6E | FAS2552, FAS2240-2 |
DS4246 | IOM6E | FAS2554, FAS2240-4 |
DS2126 | IOM6E | FAS2520, FAS2220 |
Additional Information
Use following command to find installed modules:
Cluster::> storage shelf show -fields module-type
node shelf module-type
Node-01 1.0 PSM3E
