NetApp Knowledge Base
Excessive connects and disconnects due to glitch in IC network, causing system panic
225
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
ONTAP 9.7
Issue
In an ONTAP environment where clusters with multiple nodes are peered with many other clusters, and all the inter-cluster connections in a node are closed and re-established at the same time, the system might encounter disruption while processing the new connections.
New to NetApp?
