NetApp Knowledge Base
Error in modifying bootarg.head.ontapupgrade during controller upgrade
601
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • ONTAP
  • Controller (head) upgrade using system controller replace commands
Issue
During controller upgrade, system controller replace start fails with error:
Error During the Task Execution: Error on node cluster1-01. Reason: Error in modifying bootarg.head.ontapupgrade..
Example:
cluster1::*> system controller replace show-details
Task Phase       Node            Task Name            Operation-State
Resource-release cluster1-02     Aggregate Relocation  Completed
                                 LIF Migration         Completed
                                 Volume Check          Completed
                                 Verify LIF            Completed
                                 Disable Cluster HA    Completed
                                 Disable Storage       Paused-on-error
                                 Failover
                                                       Error on node cluster1-02.
                                                       Reason: Error in
                                                       modifying
                                                       bootarg.head.
                                                       ontapupgrade..
New to NetApp?
Scan to view the article on your device
