NetApp Knowledge Base
Enclosure services device reports Command aborted by host adapter
87
Visibility:
Votes:
0
Category:
disk-shelves
Specialty:
hw
Last Updated:
Applies to
  • FAS8040
  • SAS shelves
Issue
  • Multiple minor events report for different nodes and shelves:
Minor 13:41:47 02/17/22 13:41:48 02/17/22 node_name-1 NetApp Enclosure services device shelf_switch-1:1.123L45: Command aborted by host adapter: HA status 0x4: cdb 0x1c (pls. check node_name-1syslog:/local/rsyslog/node_name-1) messages
Minor 13:41:47 02/17/22 13:41:47 02/17/22 node_name-3 NetApp Enclosure services device shelf_switch-1:1.123L45: Command aborted by host adapter: HA status 0x4: cdb 0x1c (pls. check node_name-1syslog:/local/rsyslog/node_name-3) messages
Minor 13:41:46 02/17/22 13:41:47 02/17/22 node_name-2 NetApp Enclosure services device shelf_switch-1:1.123L45: Command aborted by host adapter: HA status 0x4: cdb 0x1c (pls. check node_name-1syslog:/local/rsyslog/node_name-2) messages
  • Multiple EMS messages for SAS timeouts in different shelves and modules:
[node_name-1: isp2400_intrd: scsi.cmd.checkCondition.bridge.SAS.timeout:debug]: Enclosure services device shelf_switch-3:2.123L45: Check Condition: CDB 0x1c: Sense Data SCSI:aborted command - (0xb - 0x88 0x1 0xf)(9024).
[node_name-1: dsa_worker0: ses.exceptionShelfLog:debug]: Retrieving Exception SES Shelf Log information on channel shelf_switch-3:6 IOM module A disk shelf ID 1.
[node_name-1: isp2400_intrd: scsi.cmd.checkCondition.bridge.SAS.timeout:debug]: Enclosure services device shelf_switch-4:1.123L45: Check Condition: CDB 0x1c: Sense Data SCSI:aborted command - (0xb - 0x88 0x1 0xf)(9010).
[node_name-1: dsa_worker5: ses.exceptionShelfLog:debug]: Retrieving Exception SES Shelf Log information on channel shelf_switch-4:7 IOM module B disk shelf ID 2.
[node_name-1: isp2400_intrd: scsi.cmd.checkCondition.bridge.SAS.timeout:debug]: Enclosure services device shelf_switch-4:1.123L45: Check Condition: CDB 0x1c: Sense Data SCSI:aborted command - (0xb - 0x88 0x1 0xf)(9015).
[node_name-1: dsa_worker4: ses.exceptionShelfLog:debug]: Retrieving Exception SES Shelf Log information on channel shelf_switch-4:7 IOM module B disk shelf ID 2.
[node_name-1: isp2400_intrd: scsi.cmd.checkCondition.bridge.SAS.timeout:debug]: Enclosure services device shelf_switch-4:1.123L45: Check Condition: CDB 0x1c: Sense Data SCSI:aborted command - (0xb - 0x88 0x1 0xf)(9053).
[node_name-1: dsa_worker3: ses.exceptionShelfLog:debug]: Retrieving Exception SES Shelf Log information on channel shelf_switch-4:7 IOM module B disk shelf ID 2.
[node_name-1: isp2400_intrd: scsi.cmd.checkCondition.bridge.SAS.timeout:debug]: Enclosure services device shelf_switch-2:2.123L45: Check Condition: CDB 0x1c: Sense Data SCSI:aborted command - (0xb - 0x88 0x1 0xf)(9045).
[node_name-1: dsa_worker4: ses.exceptionShelfLog:debug]: Retrieving Exception SES Shelf Log information on channel shelf_switch-2:6 IOM module B disk shelf ID 3.
New to NetApp?
Scan to view the article on your device
