Emergency shutdown: Environmental Reason Shutdown (Battery power fault)
Applies to
- ONTAP 8
- ONTAP 9
- AFF/FAS
Issue
Node goes down with the following messages in the event logs:
[Node-01:nvram.battery.power.fault:EMERGENCY]: The NVRAM battery is not receiving power. To prevent data loss, the system will shut down in 5 minutes.
[Node-01:callhome.battery.failure:EMERGENCY]: Call home for BATTERY (power fault) CRITICAL.
[Node-01:monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery power fault)
