NetApp Knowledge Base
ESXi FCoE hosts cannot access volumes however paths are visible
604
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
san
Last Updated:
Applies to
  • ONTAP
  • FCoE
  • VMware vSphere
  • VMware ESXi
Issue
  • LUN paths visible but vCenter ESXi in different location cannot access the datastore using Fibre Channel over Ethernet (FCoE)
Example:
Output of command esxcli storage core device list
Status                                : degraded   ( means single path )
Note: "unknown" means ESXi does not recognize the state of the device or "off" may indicate Permanent Device Loss (PDL)
  • Output of vmkwarning.log while trying to access LUN
cpu12:123)WARNING: Partition: 123: Partition table read from device naa.xyz failed: I/O error
New to NetApp?
