EMS log reports the event " Call home for NVRAM EXCESSIVE CORRECTABLE ECC"
Applies to
- AFF8060
- AFF8080
- AFF A700s
- AFF-A400
- FAS8040
- ONTAP 9
Issue
- EMS log reports the event " Call home for NVRAM EXCESSIVE CORRECTABLE ECC".
[env_mgr: callhome.nvram.cecc:error]: Call home for NVRAM EXCESSIVE CORRECTABLE ECC.
- You can also read the NV CECC error counter (last-sensor-value) in the
PLATFORM-SENSORS.XML
AutoSupport file.
<asup:ROW col_time_us="********">
<name>NV Correctable ECC count</name>
<sensor-type>counter</sensor-type>
<sensor-state>normal</sensor-state>
<last-sensor-value>6 </last-sensor-value>
<value-units></value-units>
<discrete-sensor-state />
<discrete-sensor-value />
<critical-low-threshold />
<warning-low-threshold />
<warning-high-threshold />
<critical-high-threshold />
</asup:ROW>
