EMS log reports env_mgr: monitor.temp.unreadable: The controller temperature (****) is not readable
Applies to
- FAS
- AFF
Issue
- The controller is unable to read temperature sensor reports.
- EMS log reports the following events.
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Module B Expander Temp) is not readable.
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Module A Expander Temp) is not readable.
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 4 Temp) is not readable.
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 3 Temp) is not readable.
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 2 Temp) is not readable.
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 1 Temp) is not readable.
[env_mgr: monitor.temp.unreadable:error]: The controller temperature (Ambient Temp) is not readable.
[env_mgr: monitor.chassisPower.degraded:warning]: Chassis power is degraded: Sensor detecting voltage anomalies.
monitor.temp.unreadable: monitor.temp.unreadable: The controller temperature (Mezz Temp2) is not readable
