EMS log reports "scsi cmd checkCondition" error on one disk
Applies to
FAS Systems
Issue
EMS log reports "scsi cmd checkCondition" error on one disk and the error recovers automatically.
[node: Error] scsi_cmdblk_strthr_admin scsi cmd checkCondition: deviceType="Disk" deviceName="0b.00.10" cdb="0x88:000000016f1e7200:00000200" sSenseKey="SCSI:aborted command" sSenseCode="" iSenseKey="0xb" iASC="0x4b" iASCQ="0x3" iFRU="0x0" DTime="1" disk_information=""
[node: Debug] pmcsas_admin_0 scsi cmd retrySuccess: deviceType="Disk" deviceName="0b.00.10" retryCount="1" freeRetryCount="0" cdb="0x88:000000016f1e7200:00000200" dTime="118"
[node: Error] scsi_cmdblk_strthr_admin scsi cmd checkCondition: deviceType="Disk" deviceName="0b.00.10" cdb="0x88:000000016f840e00:00000200" sSenseKey="SCSI:aborted command" sSenseCode="" iSenseKey="0xb" iASC="0x4b" iASCQ="0x3" iFRU="0x0" DTime="1" disk_information=""
[node: Debug] pmcsas_admin_0 scsi cmd retrySuccess: deviceType="Disk" deviceName="0b.00.10" retryCount="1" freeRetryCount="0" cdb="0x88:000000016f840e00:00000200" dTime="118"
[node: Error] scsi_cmdblk_strthr_admin scsi cmd checkCondition: deviceType="Disk" deviceName="0b.00.10" cdb="0x88:0000000170f82a00:00000200" sSenseKey="SCSI:aborted command" sSenseCode="" iSenseKey="0xb" iASC="0x4b" iASCQ="0x3" iFRU="0x0" DTime="2" disk_information=""
[node: Debug] pmcsas_admin_0 scsi cmd retrySuccess: deviceType="Disk" deviceName="0b.00.10" retryCount="1" freeRetryCount="0" cdb="0x88:0000000170f82a00:00000200" dTime="96"
Full event details
Event:scsi.cmd.checkCondition: Disk device 0b.00.10: Check Condition: CDB 0x9a:0000000044478778:0001:0050: Sense Data
SCSI:aborted command - (0xb - 0x4b 0x5 0x0)(9).
Message Name:scsi.cmd.checkCondition
Sequence Number:21455748
Description:This
message occurs when a check condition is received from a device. A check condition is the mechanism whereby a target device reports
an informational condition or error status to the requesting host. Either the condition that generated this event is an error that
occurred during execution of the command and was not cleared by retrying the request or an informational condition reporting status
of the present operation or media state.
Event: scsi.path.excessiveErrors: Excessive errors encountered by adapter 0a on disk
device 0b.00.10.
Message Name:scsi.path.excessiveErrors
Sequence Number:21455740
Description: This message occurs when excessive
errors are encountered on this device within a short-enough time period to raise concern that there might be a faulty component
between the storage initiator and device. You can use the option 'ra.path_switch.threshold' to control how sensitive Data ONTAP(R)
is to device errors. Setting it to a higher value requires more errors to trigger this event.
