NetApp Knowledge Base
EMS log reports "nvmem.battery.fccLowCrit:EMERGENCY" error
3,124
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • AFF A220
  • AFF C190
  • AFF A300
  • AFF A200
  • FAS 2750
  • FAS 2720
  • FAS 8200
  • FAS 2650
  • FAS 2620
  • FAS 9000
Issue
  • EMS log reports the following error and recovers automatically.
[?] Fri May 22 22:56:53 JST [node: env_mgr: nvmem.battery.fccLowCrit:EMERGENCY]: The NVMEM battery full-charge capacity is critically low (30 ). To prevent data loss, the system will shut down in 20 minutes.
[?] Fri May 22 22:57:49 JST [node: env_mgr: callhome.battery.failure:EMERGENCY]: Call home for BATTERY (full charge capacity low) CRITICAL.
[?] Fri May 22 23:02:55 JST [node: env_mgr: nvmem.battery.fccNormal:notice]: The NVMEM battery full-charge capacity is normal.
  •  SP-LATEST-SYSTEM-EVENT-LOG indicate that a learning cycle is taking place at the time of the messages.
Record 835: Fri May 22 12:00:13 2020 [IPMI.notice]: f000 | 02 | EVT: 0301ffff | Bat_Lrn_Active | Assertion Event, "State Asserted"
Record 841: Fri May 22 18:08:41 2020 [IPMI.notice]: f500 | 02 | EVT: 0300ffff | Bat_Lrn_Active | Assertion Event, "State Deasserted"
New to NetApp?
Scan to view the article on your device
  • Was this article helpful?
