Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
EMS log reports "iomem.nor.op.failed:critical" error every 1 hour
182
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS8060
  • ONTAP 8.2.1
Issue
  • EMS log reports "iomem.nor.op.failed:critical" error every 1 hour.
Example:
[?] Wed Sep 09 18:47:13 JST [filer: fmm_main: iomem.nor.op.failed:critical]: params: {'slot': '3', 'part_num': '111-00903', 'reason': 'Interface timeout', 'address': '0x20000', 'model': 'X1974A-R6', 'serial': 'xxxxxxxxx', 'op': 'Erase'}
[?] Wed Sep 09 18:47:13 JST [filer: fmm_main: fmm.dev.stats.write.failed:debug]: Flash Cache in slot 3: Error occured while writing a statistics copy onboard the device at index 1.
[?] Wed Sep 09 19:47:18 JST [filer: fmm_main: iomem.nor.op.failed:critical]: params: {'slot': '3', 'part_num': '111-00903', 'reason': 'Interface timeout', 'address': '0x20000', 'model': 'X1974A-R6', 'serial': 'xxxxxxxxx', 'op': 'Erase'}
[?] Wed Sep 09 19:47:18 JST [filer: fmm_main: fmm.dev.stats.write.failed:debug]: Flash Cache in slot 3: Error occured while writing a statistics copy onboard the device at index 1.
  • Flash Cache stays in online status.
              slot 3: Flash Cache 2 (1.0 TB)
                 State:     Enabled
            Model Name:     X1974A-R6
         Serial Number:     xxxxxxxxx
           Part Number:     111-00903
        Board Revision:     C2
          FPGA Release:     3.4
            FPGA Build:     201407151914
New to NetApp?
Scan to view the article on your device
  • Was this article helpful?
