EMS LOG show "ses.status.ModuleError" message
Applies to
- IOM6
- IOM12
- IOM12E
Issue
- EMS log alert:
dsa_worker3: ses.status.ModuleError:alert]: DS2246 shelf xx on channel 0d SAS expander error for SAS shelf electronics 1: critical status. This module is on the rear of the shelf at the top left, on shelf module A.
- One of the IOMs shows critical status in
STORAGE-FAULT
section of AutoSupport (::> system node run -node node_name -command storage show fault -v
Enclosure Status: critical
Channel: 0d
Shelf: XX
Shelf Type: DS2246
Product Serial Number: SXXXXXXXXXXXXXX
Module Type: IOM6
Vendor Unique Element 83-IOM6: (SAS)
Element Status Status Bytes Status Descriptions
1 [IOM6 A] : CRITICAL 02,08,00,24 MASTER, RESERVED, RESERVED
2 [IOM6 B] : OK 01,00,00,20 RESERVED
