NetApp Knowledge Base
Does disk firmware upgrade behavior apply to the owner of the node?
52
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
FAS
Answer
Yes. If you are downloading the firmware on one side such as Node2, the disk firmware on Node2 will be upgraded when the automatic update starts. And it will apply to the disks that are owned by Node2.
Additional Information
N/A
