NetApp Knowledge Base
Does ONTAP allow mixing of drive sizes in a RAID group?
3,098
Visibility:
Votes:
3
Category:
disk-drives
Specialty:
hw
Last Updated:
Applies to
  • All FAS systems
  • All AFF systems
  • ONTAP
  • Disk drive types: SSD, SAS, NL-SAS
Answer
  • Yes, ONTAP allows mixing of different drive physical sizes in any RAID group
  • When adding larger drives to an existing RAID group of smaller drives, the larger drives will be right sized to match the usable capacity of the smaller drives.
    For example:
    • Adding a 10TB NL-SAS drive to an existing RAID group of 4TB drives results in usable capacity of 3.63TB on the 10TB drive.
      NOTE: ​​​Right sizing applies to DATA drives.  It is possible for PARITY drives to not be right sized, but additional added DATA drives will continue to be right sized
  • When adding 10TB or 16TB drives to an existing RAID group of smaller drives, ONTAP does not require RAID-TEC to be used.  This is because the usable capacity of the drive is being reduced to less than the drive capacity maximum specified by NetApp Hardware Universe.
  • To avoid possible performance issues, the minimum number of larger drives that should be added to existing RAID groups are:
    • SSDs - minimum of 2 drive
    • SAS, NL-SAS - minimum of 6 drives
  • Provided these guidelines are followed, there is no performance penalty for mixing drive capacities in the same RAID group.
Additional Information
