NetApp Knowledge Base
Disk shelf DS460C is reporting UNDER-TEMPERATURE (UT) warning alerts
249
Visibility:
Votes:
0
Category:
disk-shelves
Specialty:
hw
Last Updated:
Applies to
DS460C Storage shelf
Issue
Disk shelf DS460C reports UT WARNING alerts and after a while the warning gets auto corrected
Example:
Fri Jan 14 12:16:38 KST [node: dsa_worker0: ses.status.temperatureWarning:alert]: DS460-12 (S/N XXXXXX)
shelf 20 on channel 0b temperature warning for Temperature sensor 2: non-critical status.
Current temperature: 9 C (48 F). This module is on the rear of the shelf at the top middle inside of the PSU 1 inlet.
Fri Jan 14 12:16:47 KST [node: statd: monitor.shelf.warning:error]: Fault reported on disk
storage shelf attached to channel 0b. Check fans, power supplies, disks, and temperature sensors.
Fri Jan 14 12:16:47 KST [node: statd: callhome.shlf.fault:error]: Call home for SHELF_FAULT
Temperature Sensors:
Element Status         Status Bytes  Status Descriptions
  1: OK                01,00,2A,00
  2: NONCRITICAL       03,00,1D,01   UT WARNING
  3: OK                01,00,35,00
  4: OK                01,00,32,00
  5: OK                01,00,2B,00
  6: OK                01,00,34,00
  7: OK                01,00,31,00
  8: OK                01,00,35,00
  9: OK                01,00,33,00
New to NetApp?
