NetApp Knowledge Base
Disk goes into maintenance pool event after disk replacement
232
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • Disk Replacement
Issue
  • Disk starts testing again even after replacement.
Example:
Fri Sep 03 14:57:28 -0500 [node01: config_thread: raid.disk.maint.start:notice]: Disk 0c.10.2 Shelf 10 Bay 2 [NETAPP X343_TA15E1T8A10 NA00] S/N [Y9T0A0WUF4UR] UID [50000399:C8A02D54:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000] will be tested.
Wed Sep 08 08:20:44 -0500 [node01: config_thread: raid.disk.maint.start:notice]: Disk 0c.10.2 Shelf 10 Bay 2 [NETAPP X343_TA15E1T8A10 NA00] S/N [41M0A017F4UR] UID [5000039A:D840CCCC:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000] will be tested.
  • Disk remains "testing" status in sysconfig -r.
Example:
Maintenance disks
RAID Disk Device HA SHELF BAY CHAN Pool Type RPM Used (MB/blks) Phys (MB/blks)
testing 0b.10.2 0b 10 2 SA:B 0 SAS 10000 1713523/3509295616 1716957/3516328368
New to NetApp?
