NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
NetApp Knowledge Base
Disabling IPv4/IPv6 IP for BMC not working from ONTAP and shows error
195
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • AFF A400
  • FAS8700
  • FAS8300
Issue
Disabling IPv4/IPv6 of BMC from ONTAP not working and shows error to enable IPv6/IPv4, even though both IPv4 and IPv6 are enabled.
::> sp network modify -node node1 -address-family IPv4 -enable false
Error: command failed: IPv4 address can be disabled only if IPv6 address is enabled.
::> sp network modify -node node1 -address-family IPv6 -enable false
Error: command failed: IPv6 address can be disabled only if IPv4 address is enabled.
New to NetApp?
Scan to view the article on your device
