Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
DR mirroring offline after one node upgraded in a 2 node MetroCluster
390
Visibility:
Votes:
1
Category:
metrocluster
Specialty:
metrocluster
Last Updated:
Applies to
  • ONTAP 9
  • 2 node MetroCluster
Issue
  • One node of the two node MetroCluster has been upgraded
  • Switchback has not been performed
  • DR mirroring shows as offline
ClusterA::> metrocluster check node show -instance
                            Node Name: ClusterA-1
                        Type of Check: ha-mirroring-op-state
                         Cluster Name: ClusterA
                  Result of the Check: warning
Additional Information/Recovery Steps: Node's DR mirroring is not online. Check the FCVI connectivity to its DR partner, run the "metrocluster node show" command to verify the node and its DR partner are up and normal, then bring the DR mirroring online with the (privilege: diag) "metrocluster interconnect mirror modify -node <node> -partner-type DR -mirror-oper-status online" command.
New to NetApp?
Scan to view the article on your device
