NetApp Knowledge Base
DR Mirrors not operational on FAS8200/AFF A300 after brief connectivity loss
78
Visibility:
Votes:
0
Category:
metrocluster
Specialty:
metrocluster
Last Updated:
Applies to
  • MetroCluster IP
  • FAS8200 / AFF A300
  • Interconnect
Following the loss and recovery of MetroCluster IP connectivity, the HA, DR or AUX interconnect connectivity can be lost even though the physical connectivity is present and healthy.
The Mirror status will report as disabled and offline, even while the iWARP connections are up in metrocluster interconnect show:
Cluster1::> metrocluster interconnect show
  (metrocluster interconnect show)
                          Mirror   Mirror
                  Partner Admin    Oper
Node Partner Name Type    Status   Status  Adapter Type   Status
Node1A         Node2A HA enabled online
                                           e1a     iWARP  Up
                                           e1b     iWARP  Up
               Node1B DR disabled offline
                                           e1a     iWARP  Up
                                           e1b     iWARP  Up
               Node2B AUX disabled offline
                                           e1a     iWARP  Up
                                           e1b     iWARP  Up
Node2A         Node1A HA enabled online
                                           e1a     iWARP  Up
                                           e1b     iWARP  Up
               Node2B DR disabled offline
                                           e1a     iWARP  Up
                                           e1b     iWARP  Up
               Node1B AUX disabled offline
                                           e1a     iWARP  Up
                                           e1b     iWARP  Up
It is also possible that the Local HA will be offline because of the loss of NVRAM synchronization.  The eligibility to failover can be observed in storage failover show:
Cluster1::> storage failover show
                              Takeover
Node           Partner        Possible State Description
Node1
               node2  false    Connected to node2,
                                       Takeover is not possible: NVRAM log
                                       not synchronized
Node2
               Node1  false    Connected to node1,
                                       not synchronized
If AutoSupports available, check the METROCLUSTER-TCP-SYSCTL-MCC section in a full Autosupport and look for these errors:
name=wafl qp_id=0 state=DISCONNECTED rhp=0xfffff806190ed800 refcnt=0 last_err=12 sq=0 rq=0 tid=0 cq=0 client
p_name=wafl state=WAIT_FOR_CONN rhp=0 refcnt=0 last_err=-12
name=wafl qp_id=0 state=CONNECTING rhp=0xfffff8086ce41800 refcnt=0 last_err=12 sq=0 rq=0 tid=0 cq=0 client
name=raid qp_id=0 state=CONNECTING rhp=0xfffff8029f887000 refcnt=0 last_err=12 sq=0 rq=0 tid=0 cq=0 client
p_name=raid state=WAIT_FOR_CONN rhp=0 refcnt=0 last_err=-12
name=raid qp_id=0 state=DISCONNECTED rhp=0xfffff80287209000 refcnt=0 last_err=12 sq=0 rq=0 tid=0 cq=0 client
name=misc qp_id=0 state=CONNECTING rhp=0xfffff8087fa03000 refcnt=0 last_err=12 sq=0 rq=0 tid=0 cq=0 client
p_name=misc state=WAIT_FOR_CONN rhp=0 refcnt=0 last_err=-12
name=misc qp_id=0 state=CONNECTING rhp=0xfffff80844c73800 refcnt=0 last_err=12 sq=0 rq=0 tid=0 cq=0 client
If the  WAIT_FOR_CONN rhp=0 refcnt=0 last_err=-12 errors are present then then the issue is confirmed as Bug 1307431
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
