NetApp Knowledge Base
Controller fails to boot with error "Detected FIPS-certified encrypting disk x.x.x"
48
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS
  • AFF
  • ONTAP 9
  • FIPs Drives
  • NSE Drives
Issue
  • On a new setup, all drives show failed in maintenance mode in sysconfig -v
        slot 0: SAS Host Adapter 0a (PMC-Sierra PM8070 rev. C, SAS, <UP>)
                Firmware rev:       03.08.09.00
                Base WWN:           5:00a098:0038a6d:30
                Phy State:          [0] Enabled, 12.0 Gb/s
                                    [1] Enabled, 12.0 Gb/s
                                    [2] Enabled, 12.0 Gb/s
                                    [3] Enabled, 12.0 Gb/s
                Mini-SAS HD Vendor:        Amphenol
                Mini-SAS HD Part Number:   112-00435+A0
                Mini-SAS HD Type:          Passive Copper (unequalized) 0.5m ID:01
                Mini-SAS HD Serial Number: APF16454005221
                 ID     Vendor   Model            FW    Size
                00.0 : NETAPP   X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
                00.1 : NETAPP   X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
                00.2 : NETAPP   X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
                00.3 : NETAPP   X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
                00.4 : NETAPP   X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
                00.5 : NETAPP   X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
                00.6 : NETAPP   X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
                00.7 : NETAPP   X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
                00.8 : NETAPP   X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
                00.9 : NETAPP   X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
                00.10: NETAPP   X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
                00.11: NETAPP   X438_1625400MCSG NA04 381.3GB (781422768 520B/sect) (Failed)
  • On boot, the following message is displayed:
Dec 01 14:34:15 [localhost:disk.encryptNoSupport:error]: Detected FIPS-certified encrypting disk 0b.00.3, but bootarg.storageencryption.support indicates that FIPS disks should not be present. 24 of 24 disks checked are FIPS disks.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
