Cluster Network Degraded alerts reported multiple times due to errors on cluster ports
Applies to
- ONTAP 9.x
- NetApp CN1610 Cluster Switch
Issue
- Following cluster network degraded autosupport notification is received multiple times:
HA Group Notification (CLUSTER NETWORK DEGRADED) ALERT
- Multiple errors are reported on cluster ports of all the nodes except for one cluster port as seen in RECEIVE section of IFSTAT output.
- Cluster ports with multiple errors (Error symbol, Illegal symbol etc):
clustershell::>system node run -node <nodename> -command ifstat -a
-- interface e0b (219 days, 5 hours, 16 minutes, 2 seconds) --
RECEIVE
Frames/second: 2301 | Bytes/second: 3785k | Errors/minute: 0
Discards/minute: 0 | Total frames: 154g | Total bytes: 176t
Total errors: 43918 | Total discards: 65 | Multi/broadcast: 4452k
No buffers: 0 | Non-primary u/c: 0 | L2 terminate: 14908
Tag drop: 0 | Vlan tag drop: 0 | Vlan untag drop: 0
Vlan forwards: 0 | CRC errors: 0 | Runt frames: 0
Fragment: 0 | Long frames: 65 | Jabber: 0
Error symbol: 29328 | Illegal symbol: 14590 | Bus overruns: 0
Queue drop: 0 | Xon: 0 | Xoff: 0
Jumbo: 5634k | JMBuf RxFrames: 162g | JMBuf DrvCopy: 27146
- Single cluster port without errors:
-- interface e0b (219 days, 7 hours, 2 minutes, 24 seconds) --
RECEIVE
Frames/second: 1092 | Bytes/second: 950k | Errors/minute: 0
Discards/minute: 0 | Total frames: 47631m | Total bytes: 107t
Total errors: 0 | Total discards: 1159 | Multi/broadcast: 4473k
No buffers: 1087 | Non-primary u/c: 0 | L2 terminate: 302
Fragment: 0 | Long frames: 50 | Jabber: 0
Error symbol: 0 | Illegal symbol: 0 | Bus overruns: 22
Jumbo: 2769m | JMBuf RxFrames: 0 | JMBuf DrvCopy: 0
