Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
Cluster Network Degraded alerts reported multiple times due to errors on cluster ports
3,155
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • Cluster Switch
Issue
  • Following cluster network degraded autosupport notification is received multiple times:
HA Group Notification (CLUSTER NETWORK DEGRADED) ALERT
  • Multiple errors are reported on cluster ports of all the nodes except for one cluster port as seen in RECEIVE section of IFSTAT output.
  • You may see the cluster switch health as degraded in the system health alert show command output
  • Cluster ports with multiple errors (may see a combination of CRC err, Error symbol, Illegal symbol, etc):
clustershell::>system node run -node <nodename> -command ifstat -a
-- interface e0b (219 days, 5 hours, 16 minutes, 2 seconds) --
RECEIVE
 Frames/second:    2301  | Bytes/second:      3785k  | Errors/minute:          0
 Discards/minute:     0  | Total frames:       154g  | Total bytes:         176t
 Total errors:    43918  | Total discards:       65  | Multi/broadcast:    4452k
 No buffers:          0  | Non-primary u/c:       0  | L2 terminate:       14908
 Tag drop:            0  | Vlan tag drop:         0  | Vlan untag drop:        0
 Vlan forwards:       0  | CRC errors:        29328  | Runt frames:            0
 Fragment:            0  | Long frames:          65  | Jabber:                 0
 Error symbol:    29328  | Illegal symbol:    14590  | Bus overruns:           0
 Queue drop:          0  | Xon:                   0  | Xoff:                   0
 Jumbo:           5634k  | JMBuf RxFrames:     162g  | JMBuf DrvCopy:      27146
  • Single cluster port without errors:
-- interface e0b (219 days, 7 hours, 2 minutes, 24 seconds) --
RECEIVE
 Frames/second:    1092  | Bytes/second:       950k  | Errors/minute:          0
 Discards/minute:     0  | Total frames:     47631m  | Total bytes:         107t
 Total errors:        0  | Total discards:     1159  | Multi/broadcast:    4473k
 No buffers:       1087  | Non-primary u/c:       0  | L2 terminate:         302
 Vlan forwards:       0  | CRC errors:            0  | Runt frames:            0
 Fragment:            0  | Long frames:          50  | Jabber:                 0
 Error symbol:        0  | Illegal symbol:        0  | Bus overruns:          22
 Jumbo:           2769m  | JMBuf RxFrames:        0  | JMBuf DrvCopy:          0
  • Single cluster port reports low mW in ifconfig -vvv output:
::> system node run -node <nodename> -command ifconfig -vvv
e0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 9000
      uuid: 0320a80b-caa3-11eb-b14a-d039ea306760
      RX: 0.06 mW (-12.13 dBm) TX: 0.55 mW (-2.59 dBm)
  • You may see the follwing messages in EMS logs and health alerts generated
netif.linkErrors: Excessive link errors on network interface e2c. Might indicate a bad cable, switch port, or NIC, or that a
cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
  • The following alert may be generated against the connected switch port of the only node port without receive CRC errors:
[?] Tue Nov 01 18:13:10 -0700 [node-01: mgwd: callhome.hm.alert.major:alert]: Call home for Health Monitor process cshm: ClusterIfInErrorsWarn_Alert[switch01(FOC123456789)/Ethernet1/9].
New to NetApp?
Scan to view the article on your device
