NetApp Knowledge Base
Cluster Interconnect errors on a FAS8040 due to incorrect HA Configuration
1,346
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • Repurposing from Metrocluster to non-Metrocluster
  • FAS8040
  • ONTAP 9
Issue
While the cluster health is good, the HA failover is not:
Example:
cluster::*> cf status
Takeover
Node             Partner      Possible     State Description
cluster_01     cluster_02     false     Waiting for cluster_02, Takeover
                                        is not possible: Storage failover
                                        interconnect error, NVRAM log not
                                        synchronized, Disk inventory not
                                        exchanged
cluster_02     cluster_01     false     Waiting for cluster_01, Takeover
                                        exchanged
NOTE: Rebooting either node has no effect, nor does a power cycle or re-seat of the motherboards.
New to NetApp?
