Chassis temperature sensors on AFF-A800 unreadable by HA pair
Applies to
- AFF-A800
Issue
- AFF-A800 displays Chassis temperature is too high before prompting an environmental shutdown of the HA pair
- The following failed sensor readings may be seen:
Wed Jan 20 23:22:51 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM RTemp1) is not readable.
Wed Jan 20 23:22:51 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM LTemp2) is not readable.
Wed Jan 20 23:22:51 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM RTemp2) is not readable.
Wed Jan 20 23:22:51 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM LTemp3) is not readable.
Wed Jan 20 23:22:52 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM RTemp3) is not readable.
Wed Jan 20 23:22:52 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM LTemp4) is not readable.
Wed Jan 20 23:22:52 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM RTemp4) is not readable.
Wed Jan 20 23:22:52 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserR LTemp1) is not readable.
Wed Jan 20 23:22:52 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (LED Board Temp2) is not readable.
- Following events seen in events logs.
[NACA800-01: monitor: monitor.globalStatus.critical:EMERGENCY]: Chassis temperature is too high..
[NACA800-01: env_mgr: callhome.chassis.overtemp:EMERGENCY]: Call home for CHASSIS OVER TEMPERATURE SHUTDOWN
[NACA800-01: env_mgr: callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
