Capability security.certificate.file.system.v2 not enabled in ONTAP 9.7
Applies to
ONTAP 9.7
Issue
- System was upgraded to ONTAP 9.7, but a system capabilty might remain disabled due to an upgrade task silently failing
mgwd.log
will show periodic entries every 1 minute like:
Mon Jun 07 2021 08:41:31 +02:00 [kern_mgwd:info:2772] 0x82f256000: 0: ERR: cert_mgwd::tables::CertificateFileEntry: [verifyVserver]:113: SSL: The vserver type is not supported for certificate
Mon Jun 07 2021 08:41:31 +02:00 [kern_mgwd:info:2772] 0x82f256000: 0: ERR: cert_mgwd::tables::cert_task_entries: [upgradeTask]:614: Failed to create path entry: invalid operation
- Access
mgwd.log
via SPI URL similar to:https://<cluster_ip>
/spi/
<node_name>/etc/log/mlog/mgwd.log
