NetApp Knowledge Base
Cannot configure HA in a 2 node FAS2500 series cluster
484
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • New Setups
  • FAS 2500 series
Issue
  • The HA Interconnect link is down (HA IC done over backplane in 2552):
cluster::*>system ha interconnect port show
                               Physical  Link
                Link           Layer     Layer      Physical   Physical  Active
Node            Monitor  Port  State     State       Link Up  Link Down  Link
cluster-01   off
                            0  polling   down              0          0  false
cluster-02   off
                            0  disabled  down              0          0  false
  • In Maintenance mode we see both nodes are configured for HA:
*> ha-config show
  Chassis HA configuration: ha
  Controller HA configuration: ha
  • Attempts to bring up HA interconnect succeed:
  cluster::system ha interconnect status*> system ha interconnect link on -node cluster-01 -link 0
cluster::system ha interconnect status*> system ha interconnect link on -node cluster-02 -link 0
cluster::system ha interconnect status*> show
                       Node: cluster-01
                Link Status: up
         IC RDMA Connection: up
                       Node: cluster-01
                Link Status: up
2 entries were displayed.
  • On reboot HA interconnect fails again:
                               Physical  Link
cluster-01   off
cluster-02   off
New to NetApp?
