Call home for BATTERY ('Bat Initial FCC' unreadable) CRITICAL
Applies to
- FAS 8060
- AFF 8060
Issue
After motherboard replacement, ONTAP reports the following error messages during the boot process:
Oct 07 18:27:07 [SYD2SISFAS02:nvram.battery.sensor.unreadable:EMERGENCY]: The NVRAM battery state cannot be determined because the 'Bat Initial FCC' sensor is unreadable. To prevent data loss, the system will shut down in 5 minutes.
Oct 07 18:27:37 [SYD2SISFAS02:callhome.battery.failure:EMERGENCY]: Call home for BATTERY ('Bat Initial FCC' unreadable) CRITICAL.
Wed Oct 7 12:50:11 GMT [nvram.hw.initFail:CRITICAL]: NVRAM hardware initialization failed: DDR DIMM is not present or failed to train.
* CRITICAL ERROR *
* NVRAM has detected errors. Ontap cleared the error. *
* Data loss is likely. *
