NetApp Knowledge Base
Attention Amber LED ON After running shelf check command
45
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
DS224C
Issue
  • After the storage check command was executed, some shelf attention LED were not cleared properly and kept on and all disks LED on
  • No alerts/warnings/etc. being reported in the EMS logs.
  • There are no alarms in storage fault show
  • Fault LED ON in sasadmin expander_cli <path>.<shelf ID>.<module> "report_faults" output
Ops Panel status:
Module Fault LED     : ON
Warning:                     Local:  Remote:
****No HID warnings to report****
New to NetApp?
Scan to view the article on your device
