NetApp Knowledge Base
Amber LED reappears on a replaced disk even after turning off the fault LED
394
Visibility:
Votes:
0
Category:
disk-drives
Specialty:
hw
Last Updated:
Applies to
  • FAS/AFF Platforms
  • All versions of Data ONTAP
  • Disk Drive
Issue
  • Amber LED is seen after a failed disk is replaced with a new drive.
  • The fault LED reappears even after turning it off using the "led_off" command.
  • The replaced disk is detected from both the nodes and there are no faults reported about that disk.
Example:
Cluster::> system node run -node * sysconfig -a
00.7 : NETAPP   X343_SSKBE1T8A10 NA01 1713.5GB 520B/sect (WBXXXXX1)
00.8 : NETAPP   X343_TA15E1T8A10 NA00 1713.5GB 520B/sect (WBXXXXXX)
00.9 : NETAPP   X343_SSKBE1T8A10 NA01 1713.5GB 520B/sect (WBXXXXX2)
Cluster::> system node run -node <node-name> sysconfig -r
Pool0 spare disks
RAID Disk    Device     HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
Spare disks for block checksum
spare       0a.01.22    0a    1   22  SA:A   0   SAS 10000 1713523/3509295616 1716957/3516328368 (not zeroed)
spare       0b.00.8     0b    0    8  SA:B   0   SAS 10000 1713523/3509295616 1716957/3516328368
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
  • Was this article helpful?
