All mount points to volumes on both nodes of the cluster hang
Applies to
ONTAP 9.6P3
Issue
- Initiated upgrade of scvalcmode03 from 9.6p3->97p12 (2-node cluster)
- 97p12 should be NDU upgrade without running into Burt # 1372375.
- Sill mounts hang.
cluster::*> cluster image show-update-progress
Estimated Elapsed
Update Phase Status Duration Duration
Pre-update checks completed 00:10:00 00:00:59
Data ONTAP updates paused-on-error 01:32:00 02:02:19
Details:
Node name Status Status Description
node failed Error: Takeover failed.
Action: Use the "storage failover
show-takeover" command to view the
cause of takeover failure and the
suggested corrective actions. When
all issues are resolved, use the
"storage failover takeover -ofnode
nodea" command to trigger
takeover.
node completed
6 entries were displayed.
