Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
All disks' orange LED light on one shelf
267
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS 2750
  • ONTAP 9.7P6
Issue
  • On one shelf, all disks' orange LED light.
  • There is not failed DISK in "sysconfig -r"
Example:
::> system node run -node ******** -command sysconfig -r
      RAID Disk Device                  HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
      dparity   0b.00.3P2               0b    0   3   SA:A   0   SAS 10000 27375/56065536    27383/56081920
      parity    0b.00.5P2               0b    0   5   SA:A   0   SAS 10000 27375/56065536    27383/56081920
      data      0b.00.7P2               0b    0   7   SA:A   0   SAS 10000 27375/56065536    27383/56081920
      data      0b.00.9P2               0b    0   9   SA:A   0   SAS 10000 27375/56065536    27383/56081920
      data      0b.00.11P2              0b    0   11  SA:A   0   SAS 10000 27375/56065536    27383/56081920
      data      0b.00.13P2              0b    0   13  SA:A   0   SAS 10000 27375/56065536    27383/56081920
      data      0b.00.15P2              0b    0   15  SA:A   0   SAS 10000 27375/56065536    27383/56081920
      data      0b.00.17P2              0b    0   17  SA:A   0   SAS 10000 27375/56065536    27383/56081920
      data      0b.00.19P2              0b    0   19  SA:A   0   SAS 10000 27375/56065536    27383/56081920
Pool1 spare disks (empty)
Pool0 spare disks
Spare disks for block checksum
spare           0b.00.21P2              0b    0   21  SA:A   0   SAS 10000 27375/56065536    27383/56081920
spare           0b.00.1P4               0b    0   1   SA:A   0   SSD   N/A 228853/468690944  228861/468707328
  • After a while, the orange LED automatically go off and it can work normally.
New to NetApp?
Scan to view the article on your device
