Aggr create fails due to unexpected default node location
Applies to
- ONTAP 9
- NetApp FAS
- NetApp AFF
- Aggregate Creation (Aggr)
Issue
- node02 has enough spare disks to create an aggregate
aggr create
command fails with error:
Cluster::> aggr create -aggregate aggr1 -diskcount xx -disksize yy -simulate true -raidtype raid_tec
Error: command failed: Aggregate creation would fail for aggregate "aggr1" on node "Cluster01". Reason: xx disks needed,
but not enough matching disks of the requested size are available.
