After replacing the disk, "sysconfig -r" shows "offline" as disk state
Applies to
FAS2520
Issue
- After replacing the disk, "
sysconfig -r
" shows "offline
" as disk state.
Example:
Pool0 spare disks
RAID Disk Device HA SHELF BAY CHAN Pool Type RPM Used (MB/blks) Phys (MB/blks)
Spare disks for block checksum
spare 0a.00.7P2 0a 0 7 SA:A 0 SAS 10000 147102/301265408 147110/301281792
spare 0a.00.0P1 0a 0 0 SA:A 0 SAS 10000 709861/1453795840 709869/1453812224
spare 0b.01.10 0b 1 10 SA:B 0 BSAS 7200 1695466/3472315904 1695759/3472914816
Partner disks
partner 0a.00.0P2 0a 0 0 SA:A 0 SAS 10000 857000/1755136000 147110/301281792 (offline)
partner 0b.01.15 0b 1 15 SA:B 0 BSAS 7200 0/0 1695759/3472914816
partner 0b.01.19 0b 1 19 SA:B 0 BSAS 7200 0/0 1695759/3472914816
sysconfig -r
" of partner node can correctly display DISK status.
Example:
Pool0 spare disks
spare 0a.00.0P2 0a 0 0 SA:B 0 SAS 10000 147102/301265408 147110/301281792
spare 0b.01.20 0b 1 20 SA:A 0 BSAS 7200 1695466/3472315904 1695759/3472914816
