NetApp Knowledge Base
After TO/GB LUNs show paths in transitioning state
436
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
san
Last Updated:
Applies to
  • All versions of Clustered ONTAP prior to 9.5P4
  • All SAN hosts
Issue
Data OnTap provides three ALUA states for filer paths:
  • Active/optimized (to the node that owns the lun)
  • Active/non-optimized (to any node that does not own the lun)
  • Transitioning
The transitioning state should only be seen briefly during a takeover or giveback as the path transitions from one active state to another.
In some situations the paths become stuck in "transitioning" and the host is unable to use them.
  • Windows may report the path state as "transitioning" in DSM.
  • ESX will report IO errors and sense data returned as 0x2 0x4 0xa.
  • Aix throws the below errors
    May 30 00:39:07 hdisk1     P SC_DISK_ERR2        path  0 TEST UNIT READY  CHECK NOT READY; LOGICAL UNIT NOT ACCESSIBLE,
    ASYMMETRIC ACCESS STATE TRANSITION
    May 30 00:38:53 hdisk0     P SC_DISK_ERR2        path 10 TEST UNIT READY  CHECK NOT READY; LOGICAL UNIT NOT ACCESSIBLE,
New to NetApp?
