NetApp Knowledge Base
ASA system does not report as SAN optimized - "All SAN Array: false"
612
Visibility:
Votes:
0
Category:
fc-series
Specialty:
hw
Last Updated:
Applies to
  • ASA A800
  • ASA A400
  • ASA A250
Issue
  • The output of the san config show command does not report the system as All SAN Array: true
cluster1::> san config show
SCSI Active/Active Enabled: false
SCSI Max Transfer Length Enforced: false
Persistent Ports Enabled: false
  • You can also check nodeshell  sysconfig -a and you see All SAN Array: false
System Storage Configuration: Single-Path HA
System ACP Connectivity: Inband Active
SAS2/SAS3 Mixed Stack Support: all
All-Flash Optimized: true
Capacity Optimized: false
New to NetApp?
