AFF-A250 amber LED on while no fault is present on the system
Applies to
- AFF A250
- ONTAP 9
Issue
- Amber LED persistently set to ON for both of the nodes.
- No faults are listed in ONTAP
cluster::> system health alert show This table is currently empty. cluster::> system health subsystem show Subsystem Health ----------------- ------------------ SAS-connect ok Environment ok Memory ok Service-Processor ok Switch-Health ok CIFS-NDO ok Motherboard ok IO ok MetroCluster ok MetroCluster_Node ok FHM-Switch ok FHM-Bridge ok SAS-connect_Cluster ok 13 entries were displayed.
- However the LED is shown to be lit by the BMC:
cluster::> set adv
cluster::*> system controller fru led show
Node FRU Type Bay Slot State Lit By
host1
controller A 1 on SP
pci - 1 off -
pci - 2 off -
pci - 3 off -
pci - 4 off -
pci - 5 off -
pci - 6 off -
dimm-nv - 1 off -
dimm-nv - 2 off -
dimm - 1 off -
dimm - 2 off -
dimm - 3 off -
dimm - 4 off -
identify - 1 off -
5 entries were displayed.
- No faults can be seen in the output of the
'bmc log debug'
command from the BMC. - The issue persists through a full powercycle of the chassis.
