A800 Chassis temperature is too hot: Ambient temperature is warning high
Applies to
- AFF A800
Issue
- The following alerts are generated and cleared:
[node1: env_mgr: monitor.shutdown.chassisOverTemp:EMERGENCY]: Chassis temperature is too hot: Ambient temperature is warning high. System will be shutdown in 2 minutes
[node1: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: LED Board Temp1 is warning high (43 C).
[node1: env_mgr: monitor.shutdown.cancel:notice]: Automatic shutdown sequence canceled.
[node1: env_mgr: monitor.chassisTemperature.ok:notice]: Chassis temperature is ok.
